Shortcut to control Mix2 Transition
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Is there a shortcut, function, script, or any way to control the transition of a Mix input? Currently the only way I see to transition a mix between preview/output is by clicking on a button (cut/fade) inside the Mix input. It would greatly improve my workflow if there was a way to do this via a shortcut.
This is certainly possible using companion. So I expect there is an internal vmix shortcut.
With companion you need to set... vmix transition, with mix input number 2,3 or 4 Then the type of transition.
Note: the first input that is a mixinput is 2, the next is 3 (even if the first mix input is input number 172!)
I hope that helps.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: RickBrock  This is certainly possible using companion. So I expect there is an internal vmix shortcut.
I hope that helps. No need for companion even. Keyboard, streamdeck native, Transition function within a script all work Shortcut: Select a transition, keep input as preview but select your Mix 2,3 or 4 There is also "do you believe in life after love" :-)
