stefano
#1 Posted : Sunday, September 4, 2022 6:17:54 PM(UTC)
stefano
Italy
I often use Vmix running in a PC with windows 10 and Invidia graphic cards, using it as a player on LED walls and monitors, I often have to deal with problems regarding the displaying quality of graphic contents, like letterings giving a sensetion of scaling and low resolution, while the same contents played with VLC or Media classic on the same PC work absolutly fine. I would like to know if there are guidelines for the graphic card settings or Vmix settings in a way to resolve this issue. I want to make clear that we use directly the HDMI output of the graphic card for the vmix output, we experince this problems in FULL HD or in UHD 4K, with simple PNG files or H264 files.
If there is any help it would be awsome
#2 Posted : Wednesday, September 7, 2022 9:23:14 PM(UTC)
Please contact support via our contact page.
https://www.vmix.com/contact-us.aspx
Michael121, I have double checked and we have not received any emails from you so double check you have filled out our contact form correctly.
eduardocfs on 9/8/2022(UTC)
