jackvine
#1 Posted : Friday, September 2, 2022 5:33:05 PM(UTC)
jackvine
Hi All
Im using JSON live data to populate my Graphics thet I have made in GT, all works great.
But is there a way to trigger a logo to appear ?
One of the Data fields is nationality and I want it to be able to display a flag, where currently it only displays the 3 digit country code.
Any help appreciated
#2 Posted : Saturday, September 3, 2022 4:26:19 AM(UTC)
Originally Posted by: jackvine Go to Quoted Post
Hi All
All depends where you flag images are located
if in localfolder have the named like the nationality from your data source
say data is GBR and the flag is GBR.png just link within the title image format (datasource) as c://{0}.png for example and refering to the country code data source field
This has been addressed multiple times
jackvine
#3 Posted : Sunday, September 4, 2022 4:37:57 AM(UTC)
jackvine
Thanks for the reply, the flags are on local drive and I can get them to appear if I create a preset with the correct flag.
What Im trying to achieve Is getting the flag to auto populate from the Json data, I have 180 entries for dont want to create that many presets.
#4 Posted : Sunday, September 4, 2022 5:14:13 AM(UTC)
What Im trying to achieve Is getting the flag to auto populate from the Json data.
like i explained and in multiple posts in this forum . we do it all the time. Beats using the full filename https://www.vmix.com/help23/index.htm?DataSourcesImages.html
jackvine
#5 Posted : Sunday, September 4, 2022 4:17:25 PM(UTC)
jackvine
Thanks very much all sorted ! I was just missing the format command !
Next question soon !
