Shortcut to select a specific image in a slideshow
Joined: 5/19/2017(UTC) Posts: 103   Location: The Netherlands Thanks: 15 times Was thanked: 36 time(s) in 24 post(s)
Okay, this is a somewhat long story. But I'll spare you the details.
Is it possible to have a shortcut that fades to a specific image in a slideshow (photos input) and after that fade is done, trigger (multiple) triggers?
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
There is the SelectIndex function.
SelectIndex Photos,List: Selects item in List according to Value starting from number 1
You can use it at the beginning of a script, add a Sleep commmand for the fade time and then the actions you want to trigger.
 1 user thanked dmwkr for this useful post.
You can use it at the beginning of a script, add a Sleep commmand for the fade time and then the actions you want to trigger. Just what I was looking for, thank you so much!
