Streamdeck Yellow Exclamation
I'm having issues with the 32 Key Streamdeck. All of my profiles are gone. So I went to reset all of the keys, but when I go to shortcuts and select find, I hit any streamdeck key to find the Yellow Exclamation. I have removed and re-installed the streamdeck app with no change in outcome. Any suggestions?
Joined: 7/16/2021(UTC) Posts: 24  Location: Legnano Thanks: 2 times
Originally Posted by: SouthernSportsNetwork  I'm having issues with the 32 Key Streamdeck. All of my profiles are gone. So I went to reset all of the keys, but when I go to shortcuts and select find, I hit any streamdeck key to find the Yellow Exclamation. I have removed and re-installed the streamdeck app with no change in outcome. Any suggestions? Try to create another profile and put it in the line above and/or below compared to the existing your profile , vMix assign differents shortcut if the profile in streamdeck app is moved from original position , so you can try to move these things in order to have the match with vMix.
