rodb
#1 Posted : Tuesday, August 23, 2022 6:30:19 AM(UTC)
rodb
In a church setting I want to disable the ability for operators to change Settings. We use volunteers and not infrequently they have accidentally changed something.
This could be as simple as a toggle to enable or disable the ability to change settings, and have it apply to everything under Settings.
elvis55
#2 Posted : Tuesday, August 23, 2022 7:24:06 AM(UTC)
elvis55
Switzerland
The Preset bar at the top left hand corner of vMix is where you can quickly save your production, including Inputs, recording and streaming settings to file.
This Preset can then be recalled again at a moments notice.
https://www.vmix.com/hel...dex.htm?PresetsMenu.html
#3 Posted : Tuesday, August 23, 2022 7:49:14 AM(UTC)
It's always the volunteers that accidentally changed something ;-)
Set up a decend controller and hide the keyboard and mouse ;-) (ours can only touch a streamdeck)
