Live-Streaming Audio Output
Hi all,
I'm having issues with audio output. My input is via Web Browser so no external hardware is used. I use 2 Web Browser inputs in one vMix session. When live-streaming I noticed that audio from both Browsers are interfering. How can I correct this?
@ commerz81 Sounds like you have manually turned on the Audio for both browsers as explained in this video: Ice
Originally Posted by: IceStream  @ commerz81 Sounds like you have manually turned on the Audio for both browsers as explained in this video: Ice Thanks for your response and I'm so sorry for the late response. I need to manually turn on audio for both browsers because I'm streaming at the same time so viewers must hear sound from both browser output.
Joined: 6/5/2020(UTC) Posts: 55  Location: California Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
what do you mean they are interfering? If you are manually turning on both browsers, then of course both will play out.
