Fullscreen 1 won't change sources, stuck on 'Output'
Joined: 5/31/2020(UTC) Posts: 49  Location: California
Fullscreen 1 is showing output only, will not show/select any other sources. This is new behavior. Tried changing the source both from dropdown and by script, no luck. Using a laptop (MSI GT73 VR)with a nVidia 1080 card. The two fullscreens are fed by a mini display port and a hdmi port and both displays work fine, even when switched in either the Windows(10) display settings or the nVidia settings. And I have verified in vMix settings that the Fullscreens are attached to the right displays and are sending video. Fullscreen 1 just seems to be stuck on 'Output'. Any ideas?
FWIW, I have TB3 attached to a decklink duo2 card and all that video is just fine as well.
Edit:Just tried this with a new project and both Fullscreen 1 & 2 behave normally, i.e. both allowing me to change sources. But back to the other project with all 4 Outputs as well as both Fullscreens being used and Fullscreen 1 remains on 'Output'only.
@ VideoE
What is Output 1 set to?
Essentially, vMix needs to send the Program Output somewhere, for all editions of vMix that destination will be either Fullscreen 1 or Output 1 (typically Output 1), but if you alter that, then vMix will override Fullscreen 1 and force it to be Program Output only.
Ice Stream, thanks. That makes total 'vMix' sense. And yes, Output 1 was set to output an multilayered input... I was recreating a live show I had done with an Ascender(a 4 output screen switcher) as a vMix project and had for various reasons set it differently than I might otherwise have done. Thanks again.
