Feature Requests
add overlay channels to inputs
Joined: 6/10/2014(UTC) Posts: 20 Location: Missouri USA
Is it it possible to add two additional overlay channels for each input so that there are six static overlays instead of the current four? This would help those of us using multiple timers in a sport application (primarily hockey and lacrosse)
Thanks, Asnplus
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
@asnplus: I've read your latest posts and think that there is already a way in vMix to solve your problem: Have you ever tried to use the "multiview" tab in the input settings (double click on input window)? There you have the possibility to overlay your timer with five other inputs. So in the end you have just one input as scoreboard.
Another way could be just to create a title with all timers in one title. So you can set all the timers in one title editor window, but of course you can use your triggers as before.
Of course these are just some suggestions how I would solve this problem, but maybe this can help you
Regards, Yannick
I see what you are talking about in multiview, but should I keep that up considering all the overlays? I don't want to clutter the top of the screen just for the sake of multiviewing.
Feature Requests
