frilo
#1 Posted : Thursday, August 11, 2022 12:53:10 AM(UTC)
frilo
Germany
we are working in Vmix with Sets build with multiple Layers of graphics, cameras and videofiles.
If in a layer the videofile is played we have the only possibility to show the timer (of the file/input) to open it in the preview window.
That is a poor workaround, because we would like to use the preview as preview for the programm.
We would like to have any option to show the timer of any input. Maybe direct under the input field or as a separate input (like timer for record time), to use it as overlay etc.
Thanks for your reply,
Friedrich
raugert
#2 Posted : Thursday, August 11, 2022 2:25:32 AM(UTC)
raugert
Canada
@ frilo
Have a look at this thread. It might be what your looking for:
https://forums.vmix.com/...on-Back-Timing-Reference
frilo
#3 Posted : Thursday, August 11, 2022 11:20:52 PM(UTC)
frilo
Germany
Originally Posted by: raugert Go to Quoted Post
@ frilo
Thanks, this feature i was looking for.
Its a great Tool, good job.
The "Timecode Delay compensation" is really difficult to adjust, maybe a textfield with the value would be helpful.
Also the "Jitter" is really much, about +-1 second it displayed, maybe its the problem of the WebAPI over http...
