Joined: 6/1/2022(UTC) Posts: 3  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hello everyone! I'm using a premade virtual set and it comes with it's owns uv maps. I've downloaded a sample UV map and what I need is to create a reflection like in the example attached. How do I do that in photoshop? thanks!  Anchor_uv.png (668kb) downloaded 11 time(s). uvmap1080p.png (4,061kb) downloaded 2 time(s).
thanks!
Verically flip a duplicate of the uvmap and increase transparency and erase part where you dont want reflections Using Google search on for example "uvmap virtual set reflections" will give you several videos regarding UV maps in Virtual Sets
thanks!
Verically flip a duplicate of the uvmap and increase transparency and erase part where you dont want reflections Using Google search on for example "uvmap virtual set reflections" will give you several videos regarding UV maps in Virtual Sets Thank you, friend. It worked.
