Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Has anyone bought, or is using the TYST 4 M/E controller. If so, where where you able to find the config file. If anyone has the file, would you be kind enough to post it?
Best to all!
R
 1 user thanked RTV for this useful post.
Joined: 10/15/2020(UTC) Posts: 3  Location: Echternach Thanks: 2 times
Joined: 10/31/2022(UTC) Posts: 4  Location: Warsaw Thanks: 1 times
Originally Posted by: RTV  Has anyone bought, or is using the TYST 4 M/E controller. If so, where where you able to find the config file. If anyone has the file, would you be kind enough to post it?
Best to all!
R When you buy it please share your opinion here, is it worth spending money on?
