nowski
#1 Posted : Friday, August 5, 2022 10:30:45 PM(UTC)
nowski
Hi there, I thought I was being super smart by creating a UI for VMIX where my top frame is the call to the VMIX Social page on my live server (this works fine if loaded as a regular URL so I know the port forwarding is working)
However, when I run it in my frameset, the page cannot be found.
Which is weird. Other URLs work in the same frame
Any ideas as to how to fix this?
I tested on my local machine first (accessing from external IP with port forwarding on my router), fired up the AWS instance (can see VMIX social from same url - working fine) It wont load as part of the frame when remote.
nowski
#2 Posted : Saturday, August 6, 2022 1:11:30 AM(UTC)
nowski
Ok figured it out. We use CloudFlare and that bungs in a bit of extra Script stuff which seems to break the iframe, I put it on an IP only and it was fine, something in there must mess with what VMIX Social needs.
FYI, it works in IFRAME, OBJECT and EMBEDs
We have a system the takes all of our livestream comments and puts them in a database so I can flag questions, remove irrelevent and send live to VMIX for audience participation
