Joined: 8/5/2022(UTC) Posts: 2   Location: BUENOS AIRES
I am using Dinesat Visual, it generates a metadata for me, what I need to know is the XPath that I must load in vmix. Here is the detail of the generated metadata.
<?xml version="1.0" encoding="UTF-8"?> <stwcue version="1" xmlns="http://www.streamtheworld.com/metadata/stwcue-1.0"> <mount/> <cuepoint cache="true" type="track"> <attributes> <attribute name="cue_title">Changes - Radio Mix</attribute> <attribute name="cue_time_duration">202240</attribute> <attribute name="track_artist_name">Faul & Wad</attribute> <attribute name="track_album_name">Changes</attribute> </attributes> </cuepoint> </stwcue>
Within attributes I want to show line 1 title and 3 artist.
What configuration should I make in the XPath?
Regards.
Hello! For datasource, I have accessed that link you sent me but I can't make it work. And the dinesat metadata works because it has the information.
