Home and away stingers then replay.
Joined: 9/5/2020(UTC) Posts: 38  Location: brisbane Thanks: 2 times
Essentially i want one stinger for when the home team scores, and a different stinger for when the away team scores, followed by playing the last event on replay.
I have added the stinger video which I fire off with OverlayInput 1.
Then I have triggers set up in the stinger video to:
OnOverlayIn - ReplayLAstEvent OnOverlayIn - Fade to ReplayA
so this fires the stinger, plays and fades to the replay. All good.
I desperately need the replay video to fade back to live at the end of playing it out but it does not. I cannot add a delayed trigger to the stinger video to cut to live because sometimes i slow down or pause the replay and therefore cannot specify a time frame.
I have tried to add additional triggers to the replay chanel but this does not work that i know of.
any help would be hugely appreciated...
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Originally Posted by: adambou  OnOverlayIn - ReplayLAstEvent OnOverlayIn - Fade to ReplayA
Or use "ReplayLastEventToOutput", does the same in one. Originally Posted by: adambou  I have tried to add additional triggers to the replay chanel but this does not work that i know of.
What kind of triggers have you tried? On the ReplayA set "OnCompletion - Fade to Preview". Works for me.
you are a genius - when using PlayLastEventToOutput - it automatically fades back to live as it does with the normal replay system. No trigger on replay required. thanks sooo much
