Feature Requests
we need a simpler way to assign preview/active input to a dynamic input
I might be missing something, but i'd like a cleaner way to assign the currently previewed input to one of the dynamic inputs.
the way i currently do it is, i use a script with the following:
dim VMix_XML as new system.xml.xmldocument VMix_XML.loadxml(API.XML) API.Function("setDynamicInput1",Value:=CInt(VMix_XML.selectSingleNode("/vmix/preview").innerText))
whilst this *does* work, it might be useful to have some keyword we can use in the setDynamicInput1 (2,3,4) function like [preview] or [active] which does this for us.
it is possible there is currently a way to do this that isn't documented, but i couldn't find it anywhere. i saw some reference to using the number 0 for active, but could not find one for preview - i must admit i have not tried 0 as my use case is for preview, not active.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
section HTTP WEB API from the helpfiles ? Quote:Input
Specify an input by its number starting from 1.
0 can be used for Preview and -1 for Active.
Feature Requests
