Getting the "External Rendering Not Found" Error
Joined: 7/23/2022(UTC) Posts: 2  Location: Rio de Janeiro
So I'm trying to use Vmix to output to Clickmeeting so that I can create a webinar for a couple of clients but when I click on the External button it shows the error message of "External Rendering Not Found". Now I'm tinkering with all the External configs but had no luck getting it to work.
I have no idea what might be happening since I don't remember messing around with anything related to the outputs in the last few days and everything was working fine up until now. Does anyone have an idea of what might be happening?
@ Albanex That error typically means that you have The "External Renderer" tic box enabled but do not have a supported capture card installed for that (i.e. "not found"). If you disable that tic box, you should then be able to use the "Virtual" External Output from vMix as needed: https://www.vmix.com/hel...putwithIntensityand.htmlIce
Don't know about AJA, but a common issue with Blackmagic I/O cards is, that one had already added a port as an INPUT, and then tries to use the same port also as an OUTPUT (still happens half a year or so to me... ;)
