fideba
#1 Posted : Tuesday, July 26, 2022 6:58:11 PM(UTC)
fideba
I have a Title input with about 100 presets.
I want to create a shortcut, that moves each time to the next preset. That works fine. However, I want to detect that, if a preset contains "(N)", that preset shouldn't be selected, but instead, it should jump to the next preset (I'll use that to, in that case, move to the next slide on another input).
That detection seems to fail. Instead of moving to the next preset, it does display the "(N)", and on the next time I press the shortcut, it skips the next preset. I've been programming for a very long time (clearly not in vmix :-)), but this one puzzles me.
So in this code, I basically move to the next preset (based on the content on DynamicValue1. If it's (N), then I skip one further.
Code:
Dim VmixXML as new system.xml.xmldocument
Dim Dynamic1Val as Integer= 1
VmixXML.loadxml(API.XML)
dim title_text as string
Dim title_input_no as integer = 2
dim Dynamic1Node As XmlNode = VmixXML.selectSingleNode("/vmix/dynamic/value1")
Dynamic1Val = Dynamic1Node.InnerText
Dynamic1Val+=1
API.Function("SetDynamicValue1", Value:=Dynamic1Val)
API.Function("SelectTitlePreset",Input:="Subtitles",Value:=Dynamic1Val)
title_text=""
title_text = (VmixXML.SelectSingleNode("//inputs//input[" & title_input_no & "]//text[1]").InnerText)
if title_text="(N)" then
    Dynamic1Val+=1
end if
I'm overlooking something... :-). Any ideas ?
#2 Posted : Tuesday, July 26, 2022 7:44:46 PM(UTC)
Might be easier/more efficient to work with datasources instead of presets especially with that many data rows :-)
before being abe to evaluate the data has to go to the title first ( selected )
an easier way to check on content of a data field ( textblock) is using the scripting function = Input.Find("Titlename").Text("TextBlockName.Text") as such no neeed to read the API XML
When using a data source instead just select the next row . No need for using Dynamic values
Personally i prefer to have textfields that have to be avaluated in a hidden textblock
fideba on 7/27/2022(UTC)
fideba
#3 Posted : Wednesday, July 27, 2022 6:26:44 PM(UTC)
fideba
using input.find magically solved my issue, thanks a lot, it was driving my crazy !
Now that it works, I will try it to switch to a datasource, as you suggested, I've indeed noticed that using a large list of presets considerably slows things down.
Thanks a lot !!
Filip
fideba
#4 Posted : Wednesday, July 27, 2022 11:57:24 PM(UTC)
fideba
Thanks a lot !!
Filip
And suddenly, life became much more simpler :-)
Code:
API.Function("DataSourceNextRow",Value:="Speech1,Sheet1")
title_text=Input.Find("TitleTest").Text("Headline.Text")
    API.Function("NextItem",Input:="Slides1")
end if
Thanks again for your help !
#5 Posted : Thursday, July 28, 2022 12:49:14 AM(UTC)
Sorry couldn't resist ;-)
Code:
if Input.Find("TitleTest").Text("Headline.Text") ="(N)" then
end if
fideba
#6 Posted : Thursday, July 28, 2022 2:18:50 AM(UTC)
fideba
Code:
end if
loool, we saved another few bytes ;-)
