GT
Potential visibiity toggle bug
Joined: 12/27/2012(UTC) Posts: 5,541  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Anyone care to check this what looks like a major bug with GT titles and confirm results: (should only take a few minutes) (vMix >= 4k 25.0.0.32 title designer 3.0.0.5)
Create a title containing a TextBlock and an Image in GT Title designer. Set both with the Show Visible Toggle (Data tab) on.
Load title in vMix and play within the Title editor with each of the eye icons (toggle visibility) or use shortcuts to do so
I am experiencing that it does not always respond correctly, changes the other element instead of the one selected, flips both's visibility etc
Joined: 9/10/2015(UTC) Posts: 139  Thanks: 2 times Was thanked: 36 time(s) in 32 post(s)
Just tested with those versions and everything seems okay to me.
I'm toggling using the eye icon of Title Editor.
Also worth noting that I used a .png for the image. My items are names `TextBlock1` and `Image1`. Both items are in a layer named `Layer1`
Can you post your .gtzip so I can test it?
Edit: I just tested with Shortcuts and everything also works as expected.
 TitleBugTest.vmixZip (194kb) downloaded 2 time(s).Here's a bundle of what I tested.
Hi paco3346
Thank you very much for checking. While initially still there even when replacing image with png (was jpg) and/or using your title......it is now working just fine Must have been a fluke as it appears a vMix restart fixed it
Guess we can have this one also classified under the UNPLUG AND RESTART section of flukes ;-)
Thanks again for checking
GT
