PUT ON A STRING THE VISIBLE STATE OF A TITLE
hi folks, its possible to put on a string the visible state of some Title? like a:
dim a As string = Input.Find("My_Title.gzip").Text("RedCard.Source")
If a = ("RedCard.Source"="visibleOn") then
API.Function("SetImageVisibleOff",Input:="My_Title.gtzip",SelectedName:="RedCard.Source")
end If
Thanks For help me.
Input.Find("... gives you the content of that title element if that has as text content "visibleOn" than sure scripting can be used to determin what action to take. (btw text and imges are different types of elements!)
if you want to determin if the visibility is on or off by script of a certain element that one will have to look into the API XML and find such status . If one can not find such statusindicator than one is out of luck
In xml it appears:
<image index="0" name="CV_FORA1.Source">83e17ce7-64c1-4f11-95db-582482f115ca\CARTÃO VERMELHO.png</image>
Doesn't show if visible or not
