doing multiple AFLME streams
Joined: 5/26/2013(UTC) Posts: 148  Location: Houston, TX, US Thanks: 28 times Was thanked: 6 time(s) in 6 post(s)
I am trying to do 2 stream keys using the AFLME ";" to separate the names. This works in AFLME but doesnt seem to work through VMix - only the first name streams. I am using 12.0.0.120 64bit HD. Please advise and thanks.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Thanks for reporting this issue.
Are your stream names numbered? If so you can enter one without the number and vMix will handle the numbering automatically, otherwise this will be fixed in vMix 13.
Martin vMix
the streams have 2 different names. In AFLME, they are listed as "hsgrad;hsgradlow" with one being 1200Kbps and the other 300Kbps. This didnt work through vMix.
Also, I searched the files, but what is an "Index 0 is out of range. Parameter name: index" error? Getting it while switching though the output is fine.
Thank you
Regarding the Index 0 error, Could you install the latest update from our web site and if the error still occurs click Send Error Report.
Thanks,
Martin vMix
HWL wrote:the streams have 2 different names. In AFLME, they are listed as "hsgrad;hsgradlow" with one being 1200Kbps and the other 300Kbps. This didnt work through vMix.
I find that in vMix regardless of bitrate, spaces between filenames, or the filenames, and using the ; separator, I can only view the first stream listed in the stream key box.
since I have not received an answer on this multiple bitrate stream capability, let me ask; what effect does it have on the processor (CPU) for me to use AFLME outside of vMix; that is, does the module for Adobe Flash thats inside of vMix take up processor if I use AFLME outside of vMix? Hope I am clear.... Thanks
I replied above that this stream naming feature (with ;) will be available in vMix 13.
admin wrote:I replied above that this stream naming feature (with ;) will be available in vMix 13.
excuse me - I missed that!
