burie
#1 Posted : Friday, July 15, 2022 2:54:00 PM(UTC)
burie
Germany
Hello together.
Since I am using a StreamDeck XL there was rising a problem with shortcuts.
What I do:
I have created several projects that are very similar. So that I don't have to change various little things every time I use one of the projects, although it's easy to forget something. :)
On the stream deck I have created several pages to control Vmix overlays, slow motion etc. But not all of them work with every project and in some projects the inputs are different.
It would be a little dream if you could save shortcuts for each project separately. You load the project and the set of shortcuts and activators(!!) will be loaded.
Perhaps via a separate shortcut definition file that is stored in the project file if the project file is otherwise too large. You could also import such a shortcut file into another project, edit it further and save it again.
At the moment there is only one configuration of shortcuts and activators for ALL projects and StreamDeck pages, and that is unnecessary, confusing and sometimes I even get conflicts.
Can VMIX make this little dream come true for me?
#2 Posted : Friday, July 15, 2022 5:35:52 PM(UTC)
Check the shortcuts as local (this preset only) ?
burie
#3 Posted : Thursday, July 28, 2022 7:37:53 AM(UTC)
burie
Germany
oops... I hadn't understood the function of this checkbox until now. Thanks.
eduardocfs
#4 Posted : Friday, March 1, 2024 2:06:24 AM(UTC)
eduardocfs
Brazil
Was thanked: 19 time(s) in 8 post(s)
+1
#5 Posted : Friday, March 1, 2024 3:52:10 AM(UTC)
Originally Posted by: eduardocfs Go to Quoted Post
+1
read above, allready possible
