vb.net scripting - first layer of input to preview
Hi all...:) I wonder if someone can hep my to write a VB.net code: My goal is to be able to recognize the first layer in an input (from 10) and send it to preview.
Thanks in advance Adi
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: AdiA  Hi all...:) I wonder if someone can hep my to write a VB.net code: My goal is to be able to recognize the first layer in an input (from 10) and send it to preview.
Based on your previous posts you don't want help but for someone to write you one ! (still waiting for the few beers worth ;-) ) All necessarily info to achieve this can be found in the previous post allready mentiond scripting for dummies post combined with Google search on vb.net programming. Hint: check the API XML to find which input is on layer with index 0 of the particualr Input . Perform the PreviewInput function with the found Input key
Hi Doggy Sorry doggy but this inaccurate.
I try to learn and write on my own when my level of ability is basic And I'm progressing and seeing improvement. When I get stuck on something I look for an answer in the forum. (And yes, hoping someone will help me write the code) When you give me a piece of code I try to understand it and incorporate it into my project. And this is my way of learning and advancing in the subject (in addition to tutorials).
If you can, I'll be happy for you to help me with this as well. Thank you
I realy work hard to understed it...:) I tried something like that and with no success
dim xml as string = API.XML() dim Overlay_1 as string = "" dim activeinput as string = "" dim x as new system.xml.xmldocument dim PROGInputNodeList As XMLNodeList x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText) Overlay_1 = (x.SelectSingleNode("//input[@number='"& activeinput &"']/overlay[1]/@key").value)
sleep (1000) API.Function("PreviewInput",Input:="Overlay_1")
Is a good idea to check the items/naming in the API XML an learn about XPATH to retrieve data from the XML file
The difference between a string and a variable that contains a string to be used in a function is also important
but you are almost there (very close)
Thank Doggy.. These were good hints it works
'******* Now you owe me a few beers....:)**************
dim xml as string = API.XML() dim InputActiveName as string = "" dim OverlayKey as string = "" dim activeinput as string = ""
dim x as new system.xml.xmldocument x.loadxml(xml)
activeinput = (x.SelectSingleNode("//active").InnerText) InputActiveName = (x.SelectSingleNode("//vmix/inputs/input[@number='"& activeinput &"']/overlay/@key").Value)
API.Function("PreviewInput",Input:=InputActiveName)
Joined: 10/22/2020(UTC) Posts: 7  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hey doggy,
About those beers? Which do you even like? Pretty sure I had some answers spoon-fed to me as well by some old topics by now I reckon.
