samirbridi
#1 Posted : Friday, July 1, 2022 10:25:19 AM(UTC)
samirbridi
Brazil
I don't know if it's just me or if anyone else has the same problem I have when importing a PSD file. In this case, for example, I create the scoreboard within Photoshop, and when importing the PSD project into the GT Title, it cannot identify the images, only the texts. That is, to change some objects as "emblem" of the teams, I need to import again as an image inside GT, readjust the size and then work the change within vMix or within UTC.
Why when importing the PSD, it only sees the TEXT, and the images can't do the same? Do I need to leave them in some format within the Photoshop project?
If anyone can help me with this, I would really appreciate it, because every time a title or scoreboard is created or even some art for an event, exporting some separate objects to later import them into GT takes a lot of time and is not always perfect as the file created in Photoshop.
I believe that if you have the option to import the PSD, reading the file, it should read the layers as they should be, images, solid and texts.
I wait.
GHz
#2 Posted : Saturday, July 9, 2022 5:02:29 AM(UTC)
GHz
Italy
same problem
