i build a testing program to analyse the output (every 5 sec) of vMix with a given picture (on the left). If the output (on the right) is the same as the picture vMix automatically switch between program and preview. use: - vMix - shortcuts - WEB api Check V1.0
Joined: 4/21/2021(UTC) Posts: 10  Location: Moscow Was thanked: 1 time(s) in 1 post(s)
It would be very cool if it were possible to perform some action (for example, run a script with an emergency splash screen) if the image is longer than the time specified by the operator.
Originally Posted by: KTVChannel  It would be very cool if it were possible to perform some action (for example, run a script with an emergency splash screen) if the image is longer than the time specified by the operator. that's exactly what the software does. Not trigger a script but a transition in Vmix but a script is also possible. If you have more ideas I'd love to hear them so i can add them.
