Joined: 8/22/2013(UTC) Posts: 92  Location: Rochester, NY Was thanked: 13 time(s) in 9 post(s)
Hey there, Trying to get an animated gif in a custom xaml title working. I found this: https://github.com/XamlAnimatedGif/WpfAnimatedGifAnd supposedly it gives smooth playback. I got it working in visual studio, however when I try to add it to vMix I get a property error. Is there a set of steps for using other libraries in vMix? Some way to import the library, or specific place to put the dll? I'd also like to be able to set this animated gif image source property (or for this control the AnimatedSource property). I'm wondering if that's even going to work if I can get it working in the first place. Any thoughts? Thanks, -Brian
Joined: 12/9/2020(UTC) Posts: 4   Location: Milan Thanks: 2 times
Super interesting! Originally Posted by: tesn  Hey there, Trying to get an animated gif in a custom xaml title working. I found this: https://github.com/XamlAnimatedGif/WpfAnimatedGifAnd supposedly it gives smooth playback. I got it working in visual studio, however when I try to add it to vMix I get a property error. Is there a set of steps for using other libraries in vMix? Some way to import the library, or specific place to put the dll? I'd also like to be able to set this animated gif image source property (or for this control the AnimatedSource property). I'm wondering if that's even going to work if I can get it working in the first place. Any thoughts? Thanks, -Brian
Is your "xaml" title created/saved as a user control in visual studio where you can use the resulting .dll file as a vMix title input ? (see helpfiles)
