Hello guys
I think it's time that you add the possibility to import clip in to the vmix Relay.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Thanks Guess a bit more convincing reasoning would be appropriate instead of just saying "it's time that you add ...". Just saying ;-)
Sorry don't want to get rude. English is not my first language.
Joined: 7/24/2018(UTC) Posts: 96 Location: Carrollton, GA
Thanks: 1 times Was thanked: 15 time(s) in 11 post(s)
I have asked for this feature in the past and was asked why I would not just run it straight out the regular VMIX UI.
I explained that it would be very beneficial to be able to import directly into the Replay UI. Especially for sports. You can add what is referred to as Front Ends like "Halftime Highlights" and backends which might be a player or Team video logo. Super common thing to do in Replay operation.
My replay op only needs to be a replay op and not a full blown VMIX TD.
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1
Or have a shortcut to change in and out transition
Originally Posted by: hakan_forss  +1
Or have a shortcut to change in and out transition This is funny Giving a +1 and then saying one doesn't need it if there is a specific shortcut for something else
Originally Posted by: doggy  Originally Posted by: hakan_forss  +1
Or have a shortcut to change in and out transition This is funny Giving a +1 and then saying one doesn't need it if there is a specific shortcut for something else Both solutions can solve the same need of having the in and out of a replay being changed mid production. You have one stinger for in game replays and when you want to show highlights you can switch to another stinger.
