How to make a live bar graph
I've seen people show small examples of working bar graphs in Vmix but I was wondering if there was a way to execute it in our scenario.
We have a value between 0 and 100 sourced via python script, this value is changed anywhere between every 50ms and 200ms. We would like to create a stylized bar graph representing this value as it updates during the broadcast.
Is there any known way of creating this? Any help would be appreciated!
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
I'm sure there is a way to do this with creative use of a GT title, but personally I'd look at some external graphics software and pipe the output of that into vMix via NDI. Something like CasperCG, Processing (if you're not afraid of some coding), TouchDesigner, or Notch. Using third-party software adds to the complexity, but will often be much more flexible in terms of graphics style and rendering than trying to wrangle a solution out of titling software.
Joined: 12/27/2012(UTC) Posts: 5,467  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Joined: 1/25/2019(UTC) Posts: 326  Thanks: 22 times Was thanked: 81 time(s) in 62 post(s)
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
hello dover, how do you think it works, an example of how you would use the bars. the size of the bars would have to be updated every 50 to 200 milliseconds? similar to the audio indicator bar? a video as an example would come in handy. translated from spanish to english with google
Joined: 9/10/2019(UTC) Posts: 5  Location: Rio de Janeiro
Originally Posted by: doggy  Great development, it could help indicating a way to create the script using a .gtzip file, in my studies I can't imagine an api making the bar width according to the text or percentage. I started a search but I could see that with .xaml the path seems to be easier.
