BLVChris
#1 Posted : Thursday, June 16, 2022 2:21:53 AM(UTC)
BLVChris
Hello all.
I am new to vMix and have the following setup.
I have a Zoom L-8 interface connected to a PC via USB.
I have 3 Mics going into the L-8 via XLR on ch1,2,3.
In my vMix settings, under audio output I have my master output set to none and my headphones output set to Zoom L-8 ASIO Driver (channel 1&2).
On my L-8 I have channel 7 set to USB 1&2.
My desire here was to be able to monitor my mics and my monitoring from vMix both on the L-8 with one set of headphones.
My audio plays back through my PA correctly (which is sent over a Decklink Quad SDI output)
My vMix audio gets into the L-8 however it sounds wrong almost as if the audio bit rate is incorrectly set.
I have read over the L-8 manual but cant find any information on setting the audio bit rate, I am also unsure if this is actually the issue.
Any one had similar experience trying to use the L-8 as a capture and monitoring solution?
Thanks in advance.
DoomGoblin
#2 Posted : Sunday, June 26, 2022 2:21:33 PM(UTC)
DoomGoblin
If you go to Audio I/F (Mixer mode) and select PC/Mac then push the knob to enter, you will be confirmed as connecting to the PC.
Then select Recorder and then <Settings>, rotate the knob to get to system and then press the knob, Sample Rate is the first option, you will need to select 48kHz (and press the knob again)
Should then be in the correct bit-rate.
Cheers
Steve
BLVChris
#3 Posted : Thursday, July 21, 2022 2:06:58 AM(UTC)
BLVChris
Hello All
Thanks for getting back to me on this and sorry for the slow reply, I only just got round to testing your solution and that was the answer I was looking for. Fixed the issue I had no problem.
Thanks everyone, much appreciated.
