NDI
NDI/HX Compatible with vMix
Joined: 5/20/2022(UTC) Posts: 6  Location: Los Angeles
Tell me if I'm wrong, NDI/HX is not compatible with vMix. I've been working with this for 3+ weeks trying to get it to see these 4 cameras. Today, the only way I can get these NDI/HX cameras into vMix is to run NDI Bridge. Is there a plan for vMix to Input NDI/HX directly?
Joined: 2/18/2014(UTC) Posts: 1,843 Location: Stockholm
Thanks: 145 times Was thanked: 298 time(s) in 251 post(s)
you are wrong ;) My bet is that you have not installed the NDI HX driver.
Next time, to find answers quicker, search this forum and/or the web.
Joined: 11/15/2021(UTC) Posts: 84  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 319 times Was thanked: 263 time(s) in 233 post(s)
Yes, you can use NDI-HX cameras with vMix. I've done this. Just install the NDI-HX driver.
If NDI Studio Monitor running on the same PC can see the cameras, then vMix will as well.
If NDI Studio Monitor cannot see the cameras, you have an issue with your network.
vMix will not output NDI-HX. Only full-bandwidth NDI output.
I installed NDI Tools 5. I am able to see the NDI/HX cameras in Studio Monitor. Does vMix need. A separate driver installed in vMix? I used NDI Access Manager and was able to get these cameras to be available in vMix. Is access manager there only way or is there another driver for vMix. Can’t find anything in vMix docs for a driver specifically for NDI/HX other than the NDI Tools install.
It works with Access Manager configured.
when you install the NDI Tools (I downloaded NDI 4 Tools at the moment) you will be asked if you want to install the NDI|HX v1 Drivers
Maybe you have NDI Group Enabled in the camera (which one btw) and vMix is not supporting groups (I think).
When installing NDI 5 I did select NDI/HX. Maybe I'll re-install it.
NDI Group is not enabled.
Joined: 10/13/2012(UTC) Posts: 1,162  Location: Melbourne Thanks: 220 times Was thanked: 200 time(s) in 181 post(s)
Originally Posted by: gary.kajikawa.-nd@disney.com  Tell me if I'm wrong, NDI/HX is not compatible with vMix. I've been working with this for 3+ weeks trying to get it to see these 4 cameras. Today, the only way I can get these NDI/HX cameras into vMix is to run NDI Bridge. Is there a plan for vMix to Input NDI/HX directly? You asked, and you're wrong LOL. vMix has supported NDI|HX since release. You should not need to to use Bridge to convert. If you are using Access Manager to see the sources in vMix it would indicate that there are network restictions on mDNS. Setting up Discovery server on the network will avoid these issues.
NDI
