GT
Muiltiple Text Sources Rotating Through the Same Area
Joined: 5/3/2022(UTC) Posts: 4  Location: Texas Thanks: 1 times
Hello again vMix forums, I'm looking to have multiple pieces of information rotate through the same area. Basically all I need is for one piece of information to show up for say 30 seconds, then fade out as another piece of info fades in. The application for instance is that I need someones name and twitter handle to rotate in and out of a single box at a set 30 second interval. Is there a way to do this within GT or vmix?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: HadashiProductions  Hello again vMix forums, I'm looking to have multiple pieces of information rotate through the same area. Basically all I need is for one piece of information to show up for say 30 seconds, then fade out as another piece of info fades in. The application for instance is that I need someones name and twitter handle to rotate in and out of a single box at a set 30 second interval. Is there a way to do this within GT or vmix? Just use a ondatachange animation to you dataholder in the title with the gt title designer. Then just change the data for the title every 30 seconds and the title will take care of the animation More video tutorials to be found on that channel
Having to manually update the info is exactly what I'm trying to avoid.
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Put the data in rows of a excel spreadsheet and have it auto cycle threw
 1 user thanked Henny for this useful post.
GT
