Thanks: 8 times Was thanked: 1 time(s) in 1 post(s)
Hello!
Has anybody tried to use Mine S from Special Waves with vMix?
I'm wondering if its compatible since I'm thinking of buying one.
Thanks in advance, Petar
Hello Petar,
Yes, Mine S is compatible with all the software that support MIDI protocol. We tried and it works with vMix. You can also directly assign Led feedback on Mine S or use the LED feedback by vMix in the Activators tab on Settings. We are not present as manufacturer in the Type list on the Activators panel. It means that, as workaround, you can try the other different controller such AKAI APC 40 in order to have different LED color for different functions.
In the meantime we can write to vMix in order to ask to include Mine S in the list.
If you have any question please don't hesitate to contact us on our channels!
Specialwaves Team
