vRobyn
#1 Posted : Saturday, June 5, 2021 8:15:41 PM(UTC)
vRobyn
Sorry if this has been asked before, I have searched high and low
I want to mix up to 16 inputs coming in ASIO in a DAW (preferably Reaper) and send the output from that to vMix.
Problem is that vMix does not seem to recognise any of the ASIO outputs from Reaper (or other DAW's?)
Can anyone please point me in the right direction to solve this issue
Thanks in advance
richardgatarski
#2 Posted : Saturday, June 5, 2021 10:19:43 PM(UTC)
richardgatarski
Was thanked: 299 time(s) in 251 post(s)
does any other app recognize your DAWs via ASIO?
vMix should handle ASIO jusr fine, so probably the issue lies somewhere else.
mtone
#3 Posted : Saturday, June 5, 2021 11:19:18 PM(UTC)
mtone
Reaper has Rearoute ASIO drivers which act like virtual audio cable between applications.. i think they install by default unless you deselect that option... (in theory) you should be able to send your master output from Reaper to Rearoute1/Rearoute2 and use that as an input in vMix..
if you are mixing live inputs in Reaper through an ASIO interface then its possible you may not be able to use the same interface in vMix to monitor, that requires multi client ASIO drivers which not all interfaces have.. if thats the case and you have a second audio interface or motherboard audio you could probably use that as your vmix device for monitoring.. alternatively you could use Rearoute again as the output from vMix back into Reaper to monitor.. if you try it make sure you have sample rates matching between programs..
there is also another driver called VB-Cable which i think vMix recommend for this purpose, so that might be an option also..
wandinho
#4 Posted : Thursday, June 2, 2022 8:22:07 AM(UTC)
wandinho
Brazil
I will try to write in English
You need to follow some steps for it to work
Install Asio4All
---> https://www.asio4all.org/
Install Voicemeeter just to make a bridge, as I didn't have any audio interfaces left. (At no time did I need to open Voicemeeter, only its driver that interested me)
---> https://vb-audio.com/Voicemeeter/
How to make?
I opened Reaper and set my interface that I have at home "Alesis Core1"
Then in the lower right corner appears a green icon "Asio4all". And that's where the magic happened.
Image 1: https://borges.live/vmix/001.png
I routed the reaper's main audio output to 2 sources at the same time.
"Alesis Core1" and "Voicemeeter"
Image 2: https://borges.live/vmix/002.png
Then in vMix I added a Voicemeeter audio input.
Image 3: https://borges.live/vmix/003.png
And ready. Working
Video working: https://borges.live/vmix/reaper-to-vmix.mp4
Guest (4)
