Simsyuk
#1 Posted : Saturday, May 28, 2022 10:15:25 PM(UTC)
Simsyuk
Was thanked: 24 time(s) in 19 post(s)
Hi all, I'm struggling to get Adobe Character Animator into vMix. I've followed all the instructions by Adobe and looked at other means, but sadly I just can't seem to get it going.
My plan was to setup my 2nd pc via NDI and bring in to vMix, but vMix doesn't see it. Has anyone else using this app successfully, if so some guidance would be appreciated. Thanks.
jpetrie
#2 Posted : Wednesday, June 1, 2022 5:48:28 AM(UTC)
jpetrie
I've done Animaze (aka FaceRig) which brings the signal in as a camera input. What guide are you following and what things have you tried?
Simsyuk
#3 Posted : Wednesday, June 1, 2022 3:55:57 PM(UTC)
Simsyuk
Thanks for that, managed to follow Adobe advice and it worked, but sadly it doesn't remove the background as stated and it's out of lip sync.
I'll check out Animaze.
jpetrie
#4 Posted : Thursday, June 2, 2022 12:40:10 AM(UTC)
jpetrie
I haven't seen the Adobe Character Animator, but I'd guess you can put a green screen behind the character and use vMix to key it out.
