Hardware Compatibility
Freeze camera signal after import on second source.
Hi guys.
I have a Blackmagic deklink video card 12g 4k extreme. I have 2 inputs, 1x HDMI and 1x SDI
I connect cameras to those 2 sources.
I can import the signal no.1 without any problems, no matter if HDMI or SDI. Let us establish SDI as (1) HDMI (2)
When I import the second signal from the second connector HDMI (2), the picture from (2) HDMI works, but (1 SDI freeze) When I do refresh the source no. (1) SDI camera, 1 SDI camera shows up correctly but the picture from 2 HDMI is freezing etc. Please help thanks. Adam
Did you test it with Blackmagic Media Express if you can use SDI and HDMI Input at the same time?
We have the 4K extrem and you can use SDI or HDMI but not both at the same time
you also can check it with Blackmagic desktop video setup
