how to create a circular progress bar
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Greetings to all, recently I saw an image and I stayed with it, how to achieve a circular progress bar for vmix either in gt or xaml, or any component that works with vmix. A couple of years ago I tried in xaml with Arc but it didn't work in vmix maybe because of the framework 4 that uses this control, or that it could do some trick. some flash method could be but it is obsolete... any advice, this is just for knowledge.  translated from spanish to english by google
Originally Posted by: Papo  Greetings to all, recently I saw an image and I stayed with it, how to achieve a circular progress bar for vmix either in gt or xaml, or any component that works with vmix. A couple of years ago I tried in xaml with Arc but it didn't work in vmix maybe because of the framework 4 that uses this control, or that it could do some trick. some flash method could be but it is obsolete... any advice, this is just for knowledge.
translated from spanish to english by google Weird as it is the same image as here https://forums.vmix.com/posts/t29064-Free-animated-captions-and-infographics-for-vMixSo maybe follow the link within ? edit: there seem to be quit a few (video) tutorials for it when one googles "xaml circular progressbar"
I was also looking for a circular volume control, but I can not fid a PNG fie that has what I want, so I am trying to write a simple script to work with a graphic I found....any help would be welcomed
