vMix Call
VMIX Call, bus set for caller 1 changes to same bus caller 2
When adjusting a bus for caller 1 to bus C, caller 2 automatically changes to Bus C as well, what am I doing wrong. I'm trying to setup for 2 remote callers and 1 onsite host.
Joined: 4/23/2017(UTC) Posts: 1,476  Location: Germany Thanks: 3 times Was thanked: 193 time(s) in 173 post(s)
You can right click on a caller input and set the audio bus manually and individually. Please remember that the n-1 or mix minus is only working per bus.
When I do as you describe, other caller inputs change as qell to the last choosen bus.
Originally Posted by: mavik  You can right click on a caller input and set the audio bus manually and individually. Please remember that the n-1 or mix minus is only working per bus. arghhhh, Found it, I wasn't right clicking, but changing the input in the call settings(left click on cog). Don't understand why call inputs would change together, when adjusting this specific to an input. But right clicking was the correct solution. appologies for the user error.
vMix Call
