Joined: 4/14/2021(UTC) Posts: 15  Was thanked: 1 time(s) in 1 post(s)
There should be a settings menu, in vMix Call, where you can select your camera and mic. Currently it is quite awkward to change your camera or mic. You have to dig into your browser settings and change the defaults and then go back and refresh the page. Many devices have multiple cameras now and multiple microphones.
Having vmix call is a nice way to add in remote speakers without needing another applications that does weird things to audio and video. But not being able to choose your camera or mic is making it difficult.
Also having a little dot appear on the chat button when a new message arrives would be very nice. In the browser and somewhere in vmix.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
Originally Posted by: djones02  There should be a settings menu, in vMix Call, where you can select your camera and mic. Try https://advanced.vmixcall.comSee: https://forums.vmix.com/...27479-vMix-Call-AdvancedOriginally Posted by: djones02  Also having a little dot appear on the chat button when a new message arrives would be very nice. In the browser and somewhere in vmix. Not exactly what you are looking for, but at least for the vMix operator there is also this option: https://forums.vmix.com/...x-23-Changelog#post76338* Added "Enable Notifiation Sounds" checkbox in Settings -> Audio This currently enables the Windows system defined "New Text Message Notification" sound when new chat messages are received for vMix Call
You have been a member since:: 7/6/2017(UTC) Posts: 44
I just want to comment with a report that I am using Call for the first time and find that sometimes callers cannot get the selected audio input to "take" even when it is the same as the system audio input. No joy after a reboot. Usually sending them a new Call resolves the issue.
