andrecaleffi
#1 Posted : Friday, May 20, 2022 2:04:58 AM(UTC)
andrecaleffi
Brazil
In my VMIX I configured the local microphones to all go out on a bus channel, so I could add some audio plugins to it.
This bus channel that sends the microphone sound to the masters.
The problem is that when I play the master on VMIX Call, the sounds coming through the BUS don't come back to the guests, so they can't hear who's in the studio.
If I activate the master directly on the microphone they hear the sound on the call, but the sound does not come out through the bus.
RichDanby
#2 Posted : Friday, May 20, 2022 6:34:07 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
It was mentioned on a recent vMix video on busses that that is how it works - busses sent to master don't appear on vMix calls listening to master.
I wasn't away of that either before and hadn't seen it in the help files.
STARTING AT 7:18
One work around is you can add an audio input with a source of your local microphone bus. You could then use that to send to master, which should then show up on calls as it is an input going directly to master, or you could send it to another bus where you collect all sources you want to send to callers.
andrecaleffi
#3 Posted : Monday, May 23, 2022 10:07:22 AM(UTC)
andrecaleffi
Brazil
What I'm doing here is sending the separate mics to a specific bus for the vmix call, and everything I use on the master I put on that bus as well.
But it would be easier not to need to create this bus, because in my case whoever is on the vmix call needs to hear exactly what is going to the broadcast.
It didn't make much sense to not output the BUS audio in the vmix call.
I hope they change that in future updates.
