SDKUCSS
#1 Posted : Sunday, May 15, 2022 11:09:42 PM(UTC)
SDKUCSS
As a new vMix user, I would like to suggest the ability to sort an input playlist, much like you can sort an excel list. Because vMix adds to the bottom of the list, having the ability to sort the list by clip name, length or other attributes would be very welcome. That way, if you add to an existing playlist, you can sort the updated list by number or file name, rather than using the up or down arrows.
nikosman88
#2 Posted : Sunday, May 15, 2022 11:36:34 PM(UTC)
nikosman88
Greece
+1 also usefull i think it will be a button "insert" for easy positioning a new clip
melody
#3 Posted : Monday, May 16, 2022 2:23:46 PM(UTC)
Rank: Guest
Groups: Guests
+1
