aujaime
#1 Posted : Saturday, May 14, 2022 12:15:51 AM(UTC)
aujaime
Nicaragua
Hello All,
I am wondering which option is the most recommended.
I have seen past discussions that Windows version has the blue bars in the mixer to identify off audio.
What are other differences?
How do both versions upgrade?
Considering I would like to have the app in a tablet IPAD, Surface or any other windows tablet, What is the minimum hardware specs recommended for best performance?
Which version has the best performance and more valuable features?
https://thecloudmediagroup.onfastspring.com/
https://apps.apple.com/u...trol-surface/id978932322
Regards
Alvaro
Joeboe
#2 Posted : Saturday, May 14, 2022 2:13:02 AM(UTC)
Joeboe
I bought this app when it first came out, but was unable to download the new version, and I gave up after trying Panel Builder.......it works great, and I can design my own buttons, place them in any order I want and make them any size I want ...it is fully user friendly and looks great as I have the ability to use colours that I prefer rather than just green red and orange....at the moment, it is all I use to control vMix as it does all I need, You should give it a try.....
aujaime
#3 Posted : Saturday, May 14, 2022 3:07:07 AM(UTC)
aujaime
Nicaragua
Thanks a lot Joeboe,
I have seen Vmix Panel, but it does not have the audio mixer feature. I love that feature. Does Vmix panel have it?
Thansk
Joeboe
#4 Posted : Saturday, May 14, 2022 3:26:04 AM(UTC)
Joeboe
Until you try it, you will never know what it has....I have a template with FULL audio control...+, - db gains that I can decide how many buttons to place ...it has 'Balance' volume control, practically any thing a regular audio mixer has that is found in vMix...
Here is a screen capture of one of my templates with the Audio Mixer..I have another template with a complete different design with more inputs....
Joeboe
#5 Posted : Saturday, May 14, 2022 3:27:46 AM(UTC)
Joeboe
Here is the Video page of the same layout
aujaime
#6 Posted : Saturday, May 14, 2022 3:54:27 AM(UTC)
aujaime
Nicaragua
Incredible App, Thanks a lot for sharing
aujaime
#7 Posted : Saturday, May 14, 2022 3:57:26 AM(UTC)
aujaime
Nicaragua
So this means that I can use these templates or panels on any android tablet with a browser, right?
Joeboe
#8 Posted : Saturday, May 14, 2022 4:34:46 AM(UTC)
Joeboe
Not directly, but there is a video showing how to use it on a tablet or iPad.....
https://www.youtube.com/...UCdVwwdup4A9NMH--dYJN1ew
http://cli.re/vmix-panel-builder-user-guide
Check these links for help.....
aujaime
#9 Posted : Tuesday, May 17, 2022 2:45:11 AM(UTC)
aujaime
Nicaragua
Hello again Joeboe,,
I have been checking Vmix Panel Builder, I cannot find a solution to this.
Vmix Virtual Control Surface has two functions that I love from the audio mixer.
1) The Windows version has the ability to monitor in blue color an audio input that is not in the master/main mix like.
2) The iPad version has the ability to play, pause or restart an audio/video file input.
Sadly the iPad feature is not available in the Windows version and vice versa. Please see the images.
I have not seen in the panel builder the ability to monitor or control an audio/video file.
Have you experienced this? At least for me the most important is the blue color monitoring, but I am curious to know about the audio features of the panel builder.
Regards
Alvaro iPad.png (1,088kb) downloaded 3 time(s). Windows.png (400kb) downloaded 4 time(s).
Joeboe
#10 Posted : Monday, June 27, 2022 12:33:24 PM(UTC)
Joeboe
Guest (7)
