hadi_753
#1 Posted : Sunday, July 24, 2016 5:00:08 PM(UTC)
hadi_753
Was thanked: 5 time(s) in 1 post(s)
Hi all ,
First , huge thanks to Mr. Martin as he helped me coding this scripting ..
Here as an example of scoreboard(for table tennis) scripting .
The script do the following :
In Table Tennis , the every player got 2 services , until they reach 10-10 then every player got one serve .
What the script do is to move the dot (white circle showing how got the serve) automatically to the other player every two point until they reach 10-10 , then every player got only one .
This is impossible to do without scripting . because the dot (white circle) is an image .aside from the mistakes may happens if you do it manually .
Here is the script (if anything not clear , please let me know) :
Code:
dim i = Input.Find("SOCORE TENIS.xaml")
dim sum As Integer
sum = Convert.ToInt32(i.Text("SCORE_1_A")) +  Convert.ToInt32(i.Text("SCORE_1_B"))
dim xml = API.XML()
x.loadxml(xml)
dim n = x.SelectSingleNode("//input[@title =""SOCORE TENIS.xaml""]/image[@name = ""SELCT_TEAM_A""]")
if sum <>  "0" then
if sum < 20 then
if CLng(sum) Mod 2 > 0 Then
else
if n.InnerText = "C:\*******SELECT TEAM WHITE.png" then
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\*******\SELECT TEAM WHITE.png", 100, "SELCT_TEAM_B")
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\*******\SELECT TEAM OUT.png", 100, "SELCT_TEAM_A")
else
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\************\SELECT TEAM WHITE.png", 100, "SELCT_TEAM_A")
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\************\SELECT TEAM OUT.png", 100, "SELCT_TEAM_B")
end if
end if
else
if n.InnerText = "C:\*************\SELECT TEAM WHITE.png" then
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\*****************\SELECT TEAM WHITE.png", 100, "SELCT_TEAM_B")
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\*****************\SELECT TEAM OUT.png", 100, "SELCT_TEAM_A")
else
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\*****************\SELECT TEAM WHITE.png", 100, "SELCT_TEAM_A")
API.Function("SetImage", "SOCORE TENIS.xaml", "C:\******************\SELECT TEAM OUT.png", 100, "SELCT_TEAM_B")
end if
end if
end if
Hope the above code will be helpful for you guys ..
Thanks Mr. Martin for the support .
Regards ,
thanks 5 users thanked hadi_753 for this useful post.
corporatejames on 7/24/2016(UTC), mburel1980 on 9/18/2016(UTC), tomaszek117 on 1/6/2020(UTC), Vyacheslav on 2/7/2021(UTC), monamiga on 7/26/2021(UTC)
Jacan
#2 Posted : Monday, May 9, 2022 5:13:27 PM(UTC)
Jacan
Jamaica
I have been searching my whole "VMix" life for something like this. I have a cricket set up for which each odd number score changes the "white circle" and after every six legal deliveries, it also changes.
I am a novice to scripting and would appreciate guidance on how to use your "gift"
I am going to read all I can now.
