API to run Overlay doest work. Please help
Joined: 1/5/2022(UTC) Posts: 11  Location: east java Thanks: 2 times
Hi everyone, Sorry I'm new here. So, I have a preset of vMix that contains: Input 1 = VIDEO Input 2 = vMix call video Input 3 = Still Image (Logo) I wanna schedule auto show the logo on my vMix video output, using .bat file: start http://192.168.x.xxx:8088/api/?Function=OverlayInput1&Input=3 but when I run that .bat, it's doesn't overlay the Input 3, instead overlay Input 2. What's wrong with the code? Thank you.
you need to specify the Value
I've tried ?Function=OverlayInput1&Value=Input&Input=3
and it's still overlays the input 2.
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: richardgatarski  you need to specify the Value not for the overlay function Richard
Originally Posted by: arekkipli  Hi everyone, Sorry I'm new here. So, I have a preset of vMix that contains: Input 1 = VIDEO Input 2 = vMix call video Input 3 = Still Image (Logo) I wanna schedule auto show the logo on my vMix video output, using .bat file: start http://192.168.x.xxx:8088/api/?Function=OverlayInput1&Input=3 but when I run that .bat, it's doesn't overlay the Input 3, instead overlay Input 2. What's wrong with the code? Thank you. try using Curl Code:Curl "http://127.0.0.1:8088/api/?Function=OverlayInput1&Input=3"
Originally Posted by: doggy  Originally Posted by: richardgatarski  you need to specify the Value not for the overlay function Richard checked the shortcut function tabel and yes I didnt see any Value in Overlay, except multiview move or something. For now I already got my problem solved, though I wish someone would reply for the solution :) What I did: 1. Assign shortcut on vMix to Overlay the logo. 2. Create vbs script to press the key 3. Create bat file to automatically run the vbs.
Quote:try using Curl Code:Curl "http://127.0.0.1:8088/api/?Function=OverlayInput1&Input=3"
Tried this curl too, the result still the same. (vMix overlays the Input 2)
Originally Posted by: arekkipli  Quote:try using Curl Code:Curl "http://127.0.0.1:8088/api/?Function=OverlayInput1&Input=3"
Tried this curl too, the result still the same. (vMix overlays the Input 2) Well it worked here
Well it worked here
Thank you so much. Maybe something wrong with my vMix. I'll try later on another PC. anyway, what version of vMix You use?
Originally Posted by: arekkipli  anyway, what version of vMix You use?
what's yours ?
Ohhh I'm sorry, I missed to add "" <-- this quote mark.
It works! Thank you so much. Appreciated.
Originally Posted by: arekkipli  25.0.0.29 Lisence?
