abo78360
#1 Posted : 3 years ago
abo78360
I use Touch Portal to monitor and control vMix remotely.
The Web API provides all the commands I need.
However, the information state (http://<ip>:8088/api) does not provide the status of each multiview layer that I need for monitoring.
The layer appears in the input (vmix/inputs/input/overlay) as soon as an input is assigned to this level. This must not change.
But, currently the xml segment <overlay index="0" key="2fe8ff9d-e400-4504-85ab-df7c17a1edd4"/> does not provide the level selection state.
Is it simply possible to add this state in the segment? For example <overlay index="0" key="2fe8ff9d-e400-4504-85ab-df7c17a1edd4" state="on"/>.
Many thanks for your help
Alain
