namax
#1 Posted : Friday, April 29, 2022 7:47:54 PM(UTC)
namax
Hey, i'm currently testing the Yuan SC5C0N8 capture card.
Camera capture works just fine, but the card doesn't appear in the devices in my externals output.
Anyone have met something similar with this card ?
Cheers,
nikosman88
#2 Posted : Friday, April 29, 2022 8:42:48 PM(UTC)
nikosman88
Greece
Was thanked: 99 time(s) in 95 post(s)
Hello. Maybe im wrong but as i google search for this card, i understand that is it only input capture card and not input/output. So it is normal that you cant see it in vmix external.
But also search in their site if there is a software that can setup which port of the card is input and which is output. For example blackmagic sdi cards have a such software so search if there one for your card
