hughrichards
#1 Posted : Tuesday, April 26, 2022 1:25:15 AM(UTC)
hughrichards
Hello Everyone
How can I automate switching between two or more playlists based upon time?
For instance:
Playlist morning: switch to and play this list at 8am
Playlist evening: switch to and play this list at 8pm
Thank you for your consideration and suggestions.
Hugh
DThompson55
#2 Posted : Tuesday, April 26, 2022 2:13:43 AM(UTC)
DThompson55
I'm new to both Windows and VMix, but there's a windows command called "at" that is used to schedule commands to run at a particular time/day. Armed with that information you should be able to run a curl command to trigger a playlist by sending Function=SelectPlayList&Value=<playlistname> over http. IDK if there's an easier way, or if there are windows scheduling applications that would take the place of the "at" command and make that a little more accessible? But that would be my first try.
nikosman88
#3 Posted : Tuesday, April 26, 2022 4:14:29 AM(UTC)
nikosman88
Greece
Hello vmix needs somehow to know what time it is to play auto but it cant do it itself. There are some programms that can do it in a very good way
https://forums.vmix.com/...ler---vMixScheduler-Fork
and Vtask https://forums.vmix.com/...cheduling-and-Automation
Vtask for me is too complicated but more "professional"
VmixScheduler it does everything i need. It can create itself playlist or you can play inputs you have in vmix allready at the time you want.
Both of the them use vmix api
