distrits
#1 Posted : Thursday, April 21, 2022 2:51:57 PM(UTC)
distrits
You have been a member since:: 4/21/2022(UTC)
Italy
I have a system equipped similar to the Vmix reference system “Ruby”.
I would connect four NDI PTZ cameras. Instead of using an ethernet switch ( like the Netgear M4250) I think to use a PCIe card with 4 ethernet
ports.
Does anybody tested Vimx with this configuration?
