Set start time in countdown clock
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
I've combed the help file but can't find a shortcut or script to set a value for the start time without doing it manually every time. Does one exist?  clock settings.JPG (48kb) downloaded 9 time(s).
Originally Posted by: Egriswold  I've combed the help file but can't find a shortcut or script to set a value for the start time without doing it manually every time. Does one exist?
adjustcountdown changecoutdown Setcountdown Pausecountdown
Thanks Doggy, I figure you would chime in with an answer. I saw those but didn't think they would address the Start Time directly.
If you want to change on the fly the value of duration aka press a button--set value-->send it on air,i dont think it is possible. But with setcountdown you can have as many shortcuts you want and set them in predefined durations and select whatever you want,when you need it
