Writing GT Title text value to api command
First, I am brand new to using scripting and API commands. My question is, can someone point me in the right direction on how to use a gt title file text input as a setting in a script or command inside of Vmix UTC. My end goal is to do the following:
1. Set text inside of a GT Title file (Title = 0.3) 2. Use (Title = 0.3) as a part of the api Function command sent from VMix UTC or a script to VMix.
In other words the GT Title file becomes a settings database to be used in commands to VMix.
Thank You In Advance.
Originally Posted by: derrickrhems  First, I am brand new to using scripting and API commands. My question is, can someone point me in the right direction on how to use a gt title file text input as a setting in a script or command inside of Vmix UTC. My end goal is to do the following:
Thank You In Advance. https://forums.vmix.com/posts/m101188-Scripting-for-Dummies#post101188
