Geoff B
#1 Posted : Saturday, April 16, 2022 11:29:40 AM(UTC)
Geoff B
I'm building out a show and I have shortcuts for the operator to easily add one goal for either team using a +=1
But struggling a bit figuring out a simple way to do a shootout score (example: "2(5)"). I tried building an array of all the possible scores to use as a data source, but it looks like I can't select a new column, only a row. I'm sure someone here must have solved this already?
Thanks in advance!
- Geoff
#2 Posted : Saturday, April 16, 2022 3:36:26 PM(UTC)
Was thanked: 1009 time(s) in 831 post(s)
Thanks in advance!
- Geoff
if understood correctly
want to change the 2 but display it as 2(5) ?
- if using the combinations from a daat source put them in a column instead of rows ?
- use a hidden text field in your title and put the individual score there with your +=1 , let a small script read that and format that into a 2(5) string to be put in the visible textfield
Geoff B
#3 Posted : Saturday, April 16, 2022 10:50:38 PM(UTC)
Geoff B
Thanks in advance!
- Geoff
I've tried a few different ways. The score is just an integer 1, 2, 3, etc unless it goes to a penalty shootout, then it would become 3(0), 3(1), 3(2), etc.
I wasn't aware that you could read the contents of a text field. I tried using that knowledge to write this little script that would take the score from the text field and use that to jump to the correct row in a data source (from there, the operator could just hit a "NextRow" shortcut. But there's something wrong with my syntax and my eyes are getting blurry.
Code:
'Read current home score from title and define variable
dim stringVal as string =  Input.Find("fifascore.gtzip").Text("HomeScore.Text")
dim decimalVar as decimal = Decimal.Parse(stringVal)
dim newRow as decimal = 16*decimalVar
'Select a new starting row in the data source
API.Function("DataSourceSelectRow",value:="HomeShootout","Shooutout_Score",newRow)
#4 Posted : Saturday, April 16, 2022 11:37:30 PM(UTC)
no need for data source etc
as mentioned make some text fields invisible in the title say one for the goals and one for the shootouts: goals(shootout)
call each of the functions with a shortcut , one to update the score and one to update the shootout
per team
Code:
one for the score update
Input.Find("shootout.gtzip").Text("goal.Text")+=1   'invisible
Input.Find("shootout.gtzip").Text("Score.Text") = Input.Find("shootout.gtzip").Text("goal.Text") & "("& Input.Find("shootout.gtzip").Text("shootout.Text") &  ")"
'and óne for the shootout
Input.Find("shootout.gtzip").Text("shootout.Text")+=1   'invisible
Input.Find("shootout.gtzip").Text("Score.Text") = Input.Find("shootout.gtzip").Text("goal.Text") & "(" & Input.Find("shootout.gtzip").Text("shootout.Text") &  ")"
score here is displayed as a(b)
or put them into a ScriptStartDynamic shortcut directly
Geoff B
#5 Posted : Sunday, April 17, 2022 12:39:27 AM(UTC)
Geoff B
per team
Code:
Oh my gosh THANK YOU so much! I never would have come up with this on my own.
